SOURCE: change gas oven from natural gas to propane.
Hello littelhauler,
Most Oven manufacturers offer a conversion kit for this changeover.. I would contact a local applicance repair shop near you and tell them what you are trying to do as well as provide them with the brand and model of your stove.. They may have or be able to order a conversion kit for you..
Regards,
Rick
SOURCE: Oven burner flame is low
On top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
SOURCE: convert from propane to natural gas
it should have come with different orfices. some for propane and some for nat gas. if not go to any repair shop and they will have them.
SOURCE: gas conversion kit
If the manufacturer can't or won't supply one, check with your local LP gas supplier, if they dont do this type of service they can likely refer you to someone who can, This is not a typical "do it yourself" type project, if its to be used in a commercial application, an unapproved conversion may render the oven unsafe to operate causing a structure fire and bringing down the wrath of your local fire martial.
