SOURCE: CANON IXUS 970 IS
maybe the lens has shifted, try taking it to Canon Service Centre, (it will be fixed FOC if it's under warranty) as it does not need any spare parts, just reassimbling the lens with the body.
SOURCE: Canon Ixus 105 lens fail restart camera
This
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Canon service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera.
Please take a moment to rate the free answer I have provided for you.
SOURCE: i want to claim my
Good luck with this, but FixYa does not supply products nor register warranties; your message is directed to completely the wrong organisation.
I respectfully suggest that you contact the Canon website in your own country to register your warranty and claim any promotional gifts as we cannot assist you in this matter.
SOURCE: CANON IXUS 105 Digital Camera / Lens Error /
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
SOURCE: How do I delete the date
The date stamp on the existing images can't be moved by the camera You can move them on computer by some software as PS
