NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
SOURCE: Sansui RZ 8300 AV Receiver
Hi curtmalm
First, do a rest on the unit by disconnecting from the wall overnight. Then fire it up again to see if it recovers. Let me know here how you go.
regards
Graeme
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
SOURCE: I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
SOURCE: Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
SOURCE: i have a sansui stereo
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
