HP Pavilion DV6700Z Notebook Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cd/dvd rom not working on hp laptop
Cd/dvd rom wont work tried putting a cd in it and it doesnt do anything went to my computer but the drive is missing. its windows vistia also. can anyone help me!
  • pure_essence Feb 07, 2009
    i have hp lap top my cd/dvd drive wont work .. when you put the cd it sound like it tryin to read but nothing happen and in my computer it doesnt show i have a cd drive any ideas
Curtis Richner
Level 3:
Master:
  • Master 461 Answers
  • Posted on Dec 17, 2008
Curtis Richner
Master
Level 3:
Master:
Answers
461
Questions
0
Helped
195484
Points
1190
Is the Drive detected in the BIOS? Can you boot from your Windows or any bootable disc? If so try this solution:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
My daughter has a C551 NR running vista. The CD\DVD Rom stop working in Vista so I used an external CD drive to install Windows 7, works great. . I ordered a new drive upon HP recommendation 435778-001....
should recognize the cd rom /dvd unit automatically
lower picture is of the c300 cd unit
anything look different from the original ............lowest picture
CRX880A Compaq Presario C305LA C508US C551NR Optical Combo Drive CD-RW DVD- ROM
Cds not playing but Dvd does?
Your optical drive is not working. you need to replace it.
1helpful
Hello felows ,, i have a XP lap top ,, my problem is that the cd drive reads dvd , cd -rom , audio cd ,, but when i put a dvd - raw , it wont read it ,, the cd is a hp deskjet 2050 j510 series to...
No all cds/dvd work in all cd/dvd drives. I suspect your drive cannot read that make of cd although anothers cd rom can. Try making a copy of the disk on someone elses pc and try that in yours and you will probably find it works. You could always copy the cd to a pen drive and install it on yours from that.
Recently formated my laptop via a usb flash drive since my cd/dvd rom doesnt seem to work,and unfortunately the cd/dvd rom still doesnt work,doesnt appear under my computer,i ve no way of accessing data on...
Hello
Head of to the Acer website.Put in your model and serial # of your laptop. Find and download the cd or dvd drivers and install them on your laptop.
Also have you done the windows updates? Usually this will solve the problem.
1helpful
2answers
LG cd-rom crd 8482b Doesnt Read Dvd's
well if its new i would say return it, if not then i would suggest to use canned air and blow out the inside of it and try it again. if that don't work then i would recommend getting a new one.
My cd/dvd drive in laptop wont read anything just makes a rumblin
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
1helpful
My cd/dvd drive on my Fujitsu Siemens laptop doesnt work
Right click on my computer icon then click on property then ->hardware ->device manager
then check there is any cd/ dvd drive showing in list.
If you can see your cd /dvd driver then uninstall it.
then restart computer.
But if you cant seen then you need to refix your cd dvd rom.
For that pull your cd drive from laptop but make sure there is 1 lock system near rom just press that lock and pull drive then refix it.
DVD R/RW Wont dont anything
From the device manager, Right click on the drive and uninstall it. Then restart your computer. See if that helps.
If still not, then you can try this step.
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
1helpful
Dvds wont play in dvd rom on travel mate 2480
if the icon of DVD is there but when u try to open it doesnt bring any windows gives u error unable to read the contents then ur DVD drive lens is faulty try cleaning it with a very soft cloth open ur drive tray and u will a crystal eye shiny thing just clean it by rubbing very gently with a tissue paper or very soft cloth which is used to clean lcd's or if u have a lens cleaner cd it will be best , if it doesnt work then i will suggest changing the DVD ROM drive there are plenty of cheap DVD writer drives available on ebay under 60 $ or so try them pls vote if u find me helping
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
