Question about Toshiba Satellite A135-S4527 Notebook
Pxe-e61 system won't detect hard drive media test fail check cable then pxe-MOF exiting rom
  • Toshiba Master
  • 32,281 Answers
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on Aug 07, 2012
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Posted on Jun 16, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: i have this on my
The hard drive may just need reseating to make it work, failing that the hard drive is either faulty or the had disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and then plug it into a working computer's USB port, if you see this drive as a external drive and can see the contents of the hard drive the it is OK.
If the hard drive isn't recogonized then the hard drive is faulty and you need to get a new hard drive for your laptop and install Windows, the drivers and your programs etc.
Posted on Apr 07, 2009
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: Pxe-e61: Media test Failure check
in order to load the Operating system I request you to disable the SATA Native Mode in BIOS and then load the Operating system. 1. Please perform the below steps for the same:
a. Restart your computer.
b. When the F10 setup message appears in the lower left corner of the screen, press the F10 key.
c. Locate ‘System Configuration’ and then select ‘Device Configurations’.
d. Under ‘Device Configurations’, select ‘SATA Native Mode’ and disable the same.
e. Save the settings and exit.
Once the SATA Mode is disabled, please install the Operating System in the normal fashion using the Recovery CDs or the Operating System CDs that you have. Before installing the same, you need have the SATA Controller driver. Please follow the ’Installation Instructions’ in the SATA controller driver link given below.
2. Download the latest “Intel SATA AHCI Controller Driver” driver from the below mentioned link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId
=321957&prodSeriesId=3356620&prodNameId=3356622&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=ob-54270-1
Upon installing the same, please get back into the BIOS and enable the SATA Native Mode.
Note: The third-party information provided is to help you find the support you need. This information is subject to change without notice. HP in no way guarantees the accuracy of this third-party information. The software manufacturer will provide support for this software.
Please update your observation for us to serve you better.
I have also given you the link below for the XP Professional Drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId
=3356622&prodTypeId=321957&prodSeriesId=3356620&swLang=13&taskId=135&swEnvOID=1093
The above given information are pertaining to HP 6710b Notebook PC. If you do not have the same, please update the serial number for us to given you more information.
Posted on May 03, 2010
stannite
SOURCE: I can not get my
hi lawson1377,
it seems it can't find a bootable device in your laptop therefore trying to boot from network.
Get in the BIOS an see if the harddrive is listed and to see if the boot order is correct.
good luck.
Posted on Sep 08, 2010
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
E-E61 media test failure check cable pxe-mof exiting pxe rom. operating system not found. how do i find it
Hard drive lost communications with motherboard. Remove it and reseat it. Check BIOS if it sees the HD.
Disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
Oct 05, 2012 | Acer Aspire 9410z Laptop Computer 17"
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Dell Computers & Internet
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
My hp nx9030 keep rebooting itself with the message, PXE E61 media test failure check cable, PXE -MOF EXITING PXE ROM.what can i do
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 26, 2011 | HP Compaq nx9030 Notebook
My intel desktop DG31pr suddently just restarted and now it won`t turn on again. This is what's on my screen at the moment: Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jul 26, 2011 | Intel DG31PR Motherboard
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
My d620 got a slight knock now all thats comes up is pxe-e61 media test failure check cable and pxe-mof exiting pxe rom.and operating system not found
This code is idicative of the hard drive not being read. PXE is the code for the computer trying to boot from a network drive because it cannot find the hard drive. Take the hard drive out and try to re-seat it. When it was knocked it may have unseated the hard drive or the drive has failed.
Oct 12, 2009 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
