We have MC9090's in our store. but our new 9190's wont. They all connect fine. We have An ESSID set up aswell. which i put that in then we have a wpa2 personal, i put that in as well. then we assign ip addresses the them so we set that up in our system first then put them in to the RF gun. we get the profile set up then I goto options and enable 802.11d and then change the band to 2.4 ghz. I pretty much copy the same settings on the old gun exept for the ip address. Then when it tries to connect it says connecting but then says unable to connect. I goto find wlan and then i see it from there. click on it and hit connect and still it doesnt work. Any ideas?
SOURCE: Can't connect wifi
do the following:
click on the mobile companion icon on the menu bar at the bottom. this is the radio icon.
click on options and from the drop down menu, select regulatory. uncheck the box 802.11d and select the country where you are.
save the options.
from the drop down menu again, select the last option called export and click on the export options button. save the default registry file and you are now sorted.
SOURCE: INTERNET CONNECTION
Hi im having problme in RF Scanner motorola ,while searching for wireles connection msg prompting for scann error " Adaptor not available " I did all the solution replace required dll file and reboot,cold boot,so far no solution....
You will also need to go to settings>connections>advanced and ensure that on the two drop down menus you have either my network or my isp and ont one of each.
been resolved but i dont know how to close
