Question about 2-Way Remote Starter
COOL START REMOTE NEEDS REPROGRAMMING
I HAVE A COOL START REMOTE # M65TX605 THAT NEEDS TO BE REPROGRAMMED. IT WAS WORKING A COUPLE OF DAYS AGO BUT WHEN I TOOK IT OUT MY POCKET THE LIGHT WAS FLASHING. NO BUTTONS WERE PUSHED SO I BELIEVE IT ENTERED INTO THE PROGRAMMING PHASE AND I DID NOT GET THAT INFO FROM THE INSTALL DEALER.
  • Anonymous Jan 22, 2009
    remote works for a couple weeks with new batteries then does not lock doors or start however the blue light still works. ???
From http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Posted on Dec 23, 2008
    New Friend:
So this morning i tried to remote start my truck the truck turned on and it stayed on for 5 sec turned off again 3 sec later it turned on again for 5 sec and turned off agin doin the same problem over and over any ideas what this problem can be>? its the cool start idk which model # i bought the truck with it
Posted on Nov 18, 2011
    New Friend:
My remote was droped the buttons on the side will cause the light to come on but the rest of the buttons wont do anything at all how can i fix this
Posted on Dec 31, 2013
6ya staff
SOURCE:
I have had the Avital 4103 installed in my truck a couple of years ago. Over the last few days while driving, the horn alarm goes off by itself. It is happining about every 5-10 minutes. I need to keep...
The bypass module is most likely interfering with the vehicle data causing the OEM security to trigger. Take it to a security/remote start retailer and have the bypass module reprogrammed or replaced.
Apr 06, 2014 | 4103LX 4Button Remote Start System with...
I have a Saab 2.2tid linear (2003). the central locking system has just stopped working completely, there was no warning to suggest its the battery in the key.. before it stopped working altogether it used...
THE SAAB 9 -3 REMOTE BATTERY HAS TO BE REPLACED AND REPROGRAMMED AT THE DEALERSHIP.THE SAAB 9 - 5 YOU COULD REPLACE REMOTE BATTERY AND REPROGRAM OR SYNCHRONIZATION BY PRESSING REMOTE KEY BUTTON UNLOCK BUTTON AT LEAST 4 TIMES TO REPROGRAM KEY REMOTE TRANSMITTER.
Mar 04, 2011 | Saab 9 3 Cars & Trucks
Goog day. I have a Samsung LE40A559 LCD TV and about a week ago it stopped responding to the remote. Remote itself is working as when the TV is off and I push buttons on the remote the blue light on TV...
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed.
Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
Nov 05, 2010 | Samsung TV Remote Control
2001 volvo S60 door would not unlock with key
key needs to be reprogrammed at volvo dealer
Jun 04, 2009 | 2001 Volvo S60
Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
May 04, 2009 | Toshiba Televison & Video
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Remote starter
i worked as a chevy mechanic for many years, it sounds like your keyless entry module needs to be reprogrammed, only problem is, it takes a $4000 and a subscription to GM's service site. which most don't have, so its easier to just take it in to the dealer, however before they start working on it have them check for recalls on the programming, chevy releases reprograms on the computer systems every couple months to solve issues like this, if your van has an open reprogram on it, then the dealer will reprogram it for no charge. but make sure you have them check for open bulletins before they put any labor into finding the problem, you may get out with no bill at all if so.
Nov 10, 2008 | 2005 Chevrolet Uplander
2-Way Remote Starter Logo
17,940 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
David Thompson
Level 1 Expert
Alli Abiola
Alli Abiola
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
