I am using a Konica Minolta Maxxum 7d camera and an HP 6180 photosmart printer. I have set the camera to the mode for Picbridge and selected print date, but printer will not print date. It prints the photo directly from the camera, but without the date. When I turn the camera on, the Pictbridge logo comes on and I can do everything but get it to print the date.
HP lists the printer as DPOF compatible.
SOURCE: Minolta Maxxum 7D Lithium Battery Replacement
You need an NP-400 Li-ion lithium battery - I suspect ebay or Amazon can fix you right up.
SOURCE: CAMERA PROBLEMS
I had same problem, was about to consider sending for repair, then decided to try something: mounting the lens FORCEFULLY into position a couple of times. Working perfectly since. Apparently, some of the contact points needed some, er, tough love.
Now, when I say "FORCEFULLY", I mean "with authority", not with "reckless abandon" - don't go and snap everything into pieces!
SOURCE: won't take pictures
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Same thing happened for me after I did not use the camera
for a while with the dead battery left in the camera for a long time.
After a while of reloading camera firmware and resetting defaults, I came to
this conclusion. You need to do a mock CCD cleaning on the camera which a
built-in feature of the 7D, in which the camera locks up the mirror momentarily
so you can clean the CCD. But of course you do not need to clean the ccd
at this point. Below are procedures to help get your camera back in
operation.
1.Try turning the camera off, then take out the battery.
2.Then replace the fully charged battery back in and turn the camera on but do
not take any pictures.
3.Go to the menu of your camera and activate the CCD cleaning, which will
activate mirror lockup.
4.You will hear a mirror lock up/half exposure cycle sound.
5.One you hear this, take the lens off and make sure you can see the CCD but do
not touch the CCD or allow dust to get on it.
6.Now place the lens back over the camera and turn the camera off.
7.You will hear the mirror unlock itself, then the camera will shut down.
8.Now turn the camera back on and start taking pictures.
This worked for me and my camera started taking better pictures; however, the
same problem came up again when I let the camera sit too long with a dead
battery. So I repeated the procedures and my camera is back.
My advice is never leave a completely dead battery in the camera. Always
store fully charged batteries in the camera.
-Jay
SOURCE: BLANK (BLACK) PICTURES
Yes this is a common problem. Set the camera to take a long exposure shot (5 seconds) and with the lens off take a photo. Can you see the ccd or just the shutter (black)? If its just the shutter the shutter is jammed. It's basically a question of persisting with rebooting the camera and taking shots until the shutter frees itself.
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
However, if your camera experienced the FFB and then siezed (symptom 2) you can probably still get Sony to repair it free as its one charge for a complete camera repair. Call them up and tell them your situation.
I have the same problem with a panasonic lumix camera
[email protected]
