SOURCE: On a Cannon Powershot IXUS 86015 How do i change the language back to english?
Hey thaze,
According to the manufacturer you need to press the playback button, which looks like a triangle pointing to the right. Next you need to hold down the func. /set button, and press the menu button. Next you need to use the up/down arrows, or the right/left arrows to choose the desired language and then press the func. /set button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: want to change the language
Make sure the mode dial is in playback mode and the camera is turned on. Press and hold the Func/Set button, then press the Menu button. This will bring up the language selection screen. Release both buttons and use the arrow keys to highlight the desired language. Press the Func/Set button to select.
SOURCE: manual in frensh language
plz contact the canon customer service....because i tried my best to search the manuals online.....but i couldnt....have a good day....
SOURCE: language change
Press the menu button. Go to the "tools" menu. Select the fourth item from the bottom of the list. You should see a selection of all available languages, including english. Select it.
