Electrical Supplies Logo
Anonymous Posted on Aug 06, 2012
Leviton 6793 does not work on LED lamps? - Electrical Supplies
Treefrog15
Level 2:
Habit-Forming:
  • Expert 130 Answers
  • Posted on Jan 09, 2016
Treefrog15
Expert
Level 2:
Habit-Forming:
Answers
130
Questions
0
Helped
79881
Points
224
Only some LED lights are designed to work with a dimmer. Check with the lamp manufacturer. If the LED lamp contains an internal transformer, the Leviton 6793 says it can't be used.
Gene Haynes
Level 3:
  • Master 5,391 Answers
  • Posted on Aug 06, 2012
Gene Haynes
Master
Level 3:
Answers
5391
Questions
0
Helped
2606439
Points
14124
Look at product number again to see if numbers posted are correct.
Also include what type of device this is: rotary dimmer? slide dimmer? touch dimmer? Switch? single-pole application or 3-way? And include what you are replacing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Leviton 6842 dimmer compatible with GE J6 bulb?
If it is the falling edge type of dimmer and the lamps you wish to use are dimmable, yes.
Otherwise no.
2answers
Installed Leviton Decora Slide Dimmer switch 6672 and moving the slide turns on the lights but I have no dimming action ?? Using dimmable LED light bulbs I replaced a regular Leviton switch.
https://www.leviton.com/en/products/6672-1lw
Specs say Dimmable LED lights are fine, so that means your lights are the ones at fault. Although marked dimmable, they are aren't. Swap the bulbs out for another make. Also if you read the FAQ on the lower section of the page, there are secret switches hidden behind the slider. Also interesting to me is that on the top metal fixing plate it shows
LIGHTED OPTION
ON - OFF
Locator Light not working on leviton 6633-pl
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
1helpful
DOES THIS DIMMER WORK WITH LED LIGHT BULB
It's not quite that simple..
According to the manual for your switch, it is stated "Use with magnetic low-voltage transformers, incandescent, or 120V halogen fixtures only." Also, there is a minimum load of 40W or 40VA. Your LED lamp load will need to satisfy BOTH of these requirements. Electronic circuits are not to be "dimmed" with this dimmer - but use of either the VZE04-1L (400W max) or VZE06-1L (600W max) is supported.
You will need to provide the manufacturer and model number of the LED lamp(s) to be dimmed by this switch. Or, you can use traditional dimmers (if desired) with LED lamps that are specifically labeled as "dimmable" on their packaging.
Once the lamp model is known it will be possible to learn about their dimability assuming that they are not cheap imports with no real customer support contacts. Name brand lamps will have this support, and you can even call them yourself and inquire directly about the suitability to task for the dimmer. If the lam company doesn't know about the switch, contact Leviton with the lamp info at Customer Service: 1-800-323-8920 • FAX: 1-800-832-9538 Tech Line: 1-800-824-3005
Leviton VRCS1-1LZ one button controller. Ordered two of these, and they are behaving exactly the same. After wiring and power applied, LED indicator does not light up. Pressing the button will cause the...
here is a link to leviton u should b able to get the information u need from here as it is just a bit complicated to write it all out here. these are pdf documents and i hope they help u, cause by the time i try to explain all this it will get confusining. u should find more than just the standard docs that com with the switches.
http://www.leviton.com/OA_HTML/xxlcfbuibeCSrdSrchResults.jsp?kw=VRCS1-1LZ&st=kw&tbon=&LCR122P_pses=ZG4E54180C4F4A1F066F696AD4D1A04B1C3567D27D1DBCA7AA17ED1A4EFB77B0EB760B8E9884CA86901277844C23CB04806961B121D999014D&LCR122P=KFF2N16FTndFpwObBiMCpiGd%3AS
1helpful
2answers
Installed Acenti by Leviton single pole switch and when in "off" position, there is a flickering of light on and off, its like a pulse... model AC201-1LW... the only thing i can think thats wrong...
No you are getting a backfeed from somewhere else...either the neutral is no connected properly or you have a bad ground...
It has nothing to do with the amp. rating of the switch..
heatman101
2answers
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
1helpful
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
