Can't get efx to work
Contact Peavey toll free at 877-732-8391 or by email at [email protected],
SOURCE: all the channels shows the
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
SOURCE: what is the best suited power amp for the Peavey
that depends on your speakers, not the mixer. the amp should be matched to the speakers, in watts and in ohmage. for example, 400 watt, 8 ohm speakers should get an amp that runs at 350-500 watts at 8 ohms.
SOURCE: i have the peavey xr
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
SOURCE: Im trying to connect a peavey kb300 with a mackie
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
SOURCE: whats the best way to include a separate efx
It looks like using the GROUP output to drive the external FX and then bringing that back into the EFX return is about the only thing you can do in short of putting the effects after the main outputs then it would be on everything.
