HP Pavilion dv6000z Notebook Logo
nzakimuena Posted on Aug 05, 2012
Graphique nvidia amd w7 pavilion dv6000,6700 - HP Pavilion dv6000z Notebook
I need graphics drivers for HP D330 (DC579AV) for win 7 32bit
disktop, not told if desktop has gaphic card in the PCI-e slot.
if yes, only those driver work, at nvidia or ati./amd
if no card
that is the igpu
and all drivers for it are at hp.com
they designed and made it and only their drivers work right
matched to w7. only and DC579av)
hp.com
go to
DC579AV get the drivers.
hp ended all support ( 18 year old pc)
old old PC. came with XP new. you put w7 on and and not ask if it works there first?
chips set 865 relic, P4 ,.2003 chip set too old.
What drivers do i need for this motherboard if i install win7-64bit OS
NO OS told at all, not one clue, and w7 is max
but not told. windows 8 up i no good here.
driver match OS + chips + oem mobo design.
a 3 way match, yes there are ways to cheat but I will not type 10 pages of text to do that. sorry.
why not just try first see what fails and work those
load to ssd drive and is 30mins work too top all that, w7.
It will not catch fire, loading w7.
great question but foxconnchannel.com DIY mobo went dead 2012.
so support ended then.
if mobo came new in OEM PC say so and maker name and model.
we can not guess OEM mobo, like you present.
Foxconn M61PMV (2008 new)
coin cell 6years old , and can be good.
Support AMD socket AM3/ AM2
NVIDIA GeForce 6100/ nForce 430
Realtek 6-channel audio chip (M61PMV-E)
Nforce is dead now.
but the last AMD driver, MS ended support to , due to AMD ends
ok here it the the last Nforce driver from AMD, official site
https://www.nvidia.com/Download/driverResults.aspx/14875/en-us
see that. vista 64bit and,
yes w7 there.
Does anyone know where to get the schematic for the dv6550us motherboard?
The closest I come to an HP Pavilion dv6550us, on HP Support, or on the internet is;
Pavilion dv6550tx
Next inline is Pavilion dv6560us,
then Pavilion dv6450us
Not available to the public.
Do have a Block Diagram,
Models that use an AMD processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV9000-AMD-Notebook-Laptop-Quanta-AT8-Schematic.jpg
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Motherboard chipset is an Nvidia MCP51M
Which is the mobile version of Nvidia GeForce Go 6100, or Go 6150;
and Nvidia nForce 430,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_6_.28Go_6xxx.29_Series
Graphics chipset,
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
Conexant CX20549-12 audio chipset
Realtek RTL8101C Ethernet chipset
Models that use an Intel processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV6700-Intel-Notebook-Laptop-Quanta-AT3-Schematic.jpg
Uses the Socket P processor socket,
http://en.wikipedia.org/wiki/Socket_P
Both use the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, in the DC - DC circuit; as far as I know.
Both are Obsolete, but there are cross match examples out there.
(FDS6679AZ for FDS6679, for one)
Indicates HP Pavilion dv9000 series, and AMD; but also matches up to the Pavilion dv6500 series,
http://www.scribd.com/doc/89356925/HP-DV9000
Scroll down. (Zoom In icon { + } at TOP to increase view size,
Zoom Out icon { - } to decrease view size )
Asking for a Schematic, do I assume you are attempting
Board Level Component replacement?
What SMD/SMT IC component are you trying to replace?
(Surface Mount Device/Surface Mount Technology. Integrated Circuit)
Motherboard chipset info, and processor socket info, for processor upgrade.
Same thing for Ram Memory upgrade.
It does use DDR2 Sdram (SO-DIMM), and at 667MegaHertz, to my knowledge.
What usually goes bad on the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's?
The cooling for the graphics chipset is inadequate, therefore the graphics chipset overheats, and partially melts the Solder Joints in the BGA surface mount.
Resulting in no graphics.
Power MOSFET's in DC - DC circuit go bad.
Continued in Comment
HP Pavilion dv9000us (RP246UA#ABA) Maximum Ram?
ask the top makers of memory that, kingstone
the limit is clearly in the manual
RTM
http://www.hp.com/ctg/Manual/c01311536.pdf
page 10 pdf.
for better answer ask HP directly? yet? we are not HP.
https://h30434.www3.hp.com/
for RAM to work (only right Ram spec, works)
AND the BIOS must like it too. if not fails.
all upgrades of any type can cause issues.
so we do not upgrade or work the issues, 1 by 1.
its your call what you want to spend or time wasted, on upgrades.
upgrade from what, XP , vista? unsaid.
using what media, HP , there is non now for 11 year old HP.
so my guess using MS disks, from what source?
endless bad sources exist, a retail boxed set w7 from MS, ? goodl but
MS does not sell W7 direct now, that means finding NOS
new old stock off a shelf , for $120 retail .
issues with upgrades are (besides just RAM)
are vast.
chips that fail to have working driver for W7 are vast.
LAN
WIFI
sound
to name 3. (even video GPU if unlucky) non ATI non Nvidia.
now RAM start with #1 in the business. ask them.
https://www.kingston.com/us
2answers
Motherboard posts, Windows 7 installed, all drivers updated, computer randomly throws up a blank screen while in Windows and I have to reboot. Onboard video problem? BIOS setting I'm missing? MSI...
well lots of cause for black screen , on the fly, w7 running.
i guess caps lock key dead too? showing that CPU is offlline if dead.
good fact there on Ubuntu.
but is Ubuntu on other drive or usb or DVD?
my guess is HDD is bad holding w7
as most are that the SATA is it?
nforce is bad news, there is no future support, a DOA EOL chip set.
but not your pc problems'
caps lock dead
control +alt + del , dead. too?
turn w7 sounds on (system sound)_
THEN AT BLACK SCREENED, unplug keyboard usb hear dingdongg , and reversed that.? if not dig windows is dead.
same with adding mouse or usb memory stink, ding?
or just wrong GPU driver loaded in to w7
last no GPU card installed now, use VGA local port does it fail w7
I've got a HP Pavilion DV 9700 with 3GB RAM, it's running Windows 7 professional 32bit. It has a video card Geforce 8600m GS, I downloaded the drivers from the Nvidia web page but the driver doesn't seem...
ITS a NOTBOOK, with fixed GPU. (cant change that)
so what was this PC new. what OS? VISTA
and you put on w7?
if yes, did you look up the rules for w7 on that. first.
that is step one, btw.
i think your OS was changed from VIsta to w7
try the Vista driver below. it might work,.
so why not use the HP drivers,for your PC and leave nvida out.
if the HP drivers fails, due to wrong OS, the ask Nvida for help.
not HP. see? If HP does not support w7 , asking them is fail.
first get right 32bit and 64bit, do that first. then pick W7
then pick GPU driver.
ask HP no matter.
they had Nvida chip or Intel, using the wrong chip driver is FAIL
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9700-entertainment-notebook-pc-series/3632106
Heip
Try the makers website :)
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
