SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
SOURCE: Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: burning smell when on.
You could have an issue with lint that has accumulated surrounding the heat element, motor, etc., or there may be some faulty wiring. Contact an appliance service company.
SOURCE: My t712c asko dryer is making some loud noises.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
nfgnc
SOURCE: Asko t712c dryer was heating up but drum not
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
There
The
going bad...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
