I have always been able to connect my camera's cable to my computer and upload all my pictures. However, recently, although I do exactly the same thing, the pictures onto my computer have not been transfering from my camera to my computer.
How can I do so now? And, what is wrong? Why have I been unable to do so recently?
I have the exact same problem. My camera is a kodak easyshare cx7430. Ii just stopped though everything else works well. I have followed all Kodaks instructions but same problem. Help please lucyshines
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: lines on pictures
Your CCD unit in your camera needs to be replaced. Contact Kodak.com to see if camera is still covered under warranty.
SOURCE: my photos wull not upload onto the pc from my
To up load you have to make that the Kodak easyshare ICON on your desk top is open. Then turn on your camera plug in the usb cable to your camera and to the PC . the pic will up load automatic . I hope this helps .
SOURCE: trouble uploading "duplicate" pictures
I've just found a fix for this problem after fighting it myself for a week. Don't use the transfer window that Easyshare gives you when you connect your camera (or which is also available under the tools/cameras/viewers dropdown menu).
Cancel this window if it comes up. Then select "add pictures" from the file dropdown menu (as if you were going to add pictures from your hard-drive to the easyshare gallery). The camera will appear in the folder list. Open the m1063 folder, select the pictures you want (or select all) then click the "add pictures" button.
-Neil
SOURCE: It won't upload my pictures! Kodak Easyshare C813
Buy an inexpensive card reader to download your pictures to a folder you create on your desktop.
SOURCE: My Kodak EasyShare M320 won't let me upload pictures
Get yourself a card reader do download pics. This one is $13 at Walmart.
USB cabel okay and other ports working just not with camera
Have you tried a new USB cable? Or a different USB port?
