Power turns on ok and wash cycle completes with no dramas. As soon as it starts to drain for the first rinse cycle however, the power turns off, with no lights appearing on the machine. I then have to wait approx. 5 minutes before the power will turn back on again. I have to repeat this process quite a few times until eventually, the water will start to drain. After the rinse cycle, the 2nd rinse cycle (where it fills up with water again) completes without stopping, however, once I get to the spin cycle and it starts to drain again, the problem with the power turning off starts again. Anybody have any ideas how to fix this please ?
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
SOURCE: Appears to have turned on but won't start running water to start
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Note: If your repair problem isn't listed, click hereto email the RepairGuru. He will give you the help you need.
SOURCE: Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
