Just need to change it back
"Did it change to a Euro, or exclamation sign? You possibly pressed the Fn button with one of the keys that have (usually) a blue descriptor/icon. Or, a Windows "feature" is that you can change languages by pressing Alt + SHIFT simultaneously. To turn off this feature:
1. Near the bottom right of the screen might be an icon of a keyboard.
Left click and select US keyboard if it's set to another language. This turns it
off but it doesn't prevent it from getting switched again.
2. The permanent fix is to disable the key combination. There's two
ways to do this. Right-click on the keyboard icon and click "Settings". Select the "Advanced Key Settings" tab. Click the "Change Key
Sequence" button and select "not assigned". Click OK a few times and you're done.
3. If you cannot locate the keyboard icon you can get at this through
the Control Panel. Go to Regional and Language control panel. Select the "Keyboards and Languages" tab and click the "change keyboards" button. This
takes you to the language settings described in step 2 above.
SOURCE: the writing under the desktop icons has been
This seems like a language issue. You need to go to control panel, regional settings and check each tab for language chosen. THis should solve your problem.
SOURCE: change keyboard layout for acer aspire
What version of windows are you on?
if you dont know go to
start -> run (or press winkey + R)
type in winver & press enter
post the version here
in most cases you will find the keyboard settings you want under region & language settings in the control pannel
