I hooked up my xbox 360 to my LCD computer monitor via the Xbox 360 VGA HD AV Cable. I'm currently using DVI for my PC display as well.
Problem: When I try to switch inputs from DVI to VGA, it says no input signal, and reverts back to DVI. I just got this Xbox 360 VGA HD AV Cable in the mail today, so there's the possibility that the cable is defective, but I'm trying to rule out all other possibilities first.
Side note: I can't test if the sound works because I have no Y-adapter. In the next week I will get an Astro Mixamp in the mail, and I will be able to test the audio that way.
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
lololol HD to standard video - standard video back to HD is going to cause some issues. Go straight HD to HD with a hdmi to dvi instead. Even if your tv cant do HD theres a loss of information and signal for every adapter you put in and the length of the cord.
HDMI to DVI works better than HDMI to VGA because VGA only uses simple RBG scheme.
Additionally the only way i see the Xbox getting connected to the extrenal speakers is if you get the speakers connected to the monitor/tv or whatever you are using directly. I havent tried or do not know of any way to connect the Xbox to speakers directly.
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
HI, Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor. The cable would look something like this http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
hi if you have an xboxelite the you can do it via hdmi cable, but if you have the normal xbox360 then its just the vga plug ime affraid hope this helps
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
Start the Xbox 360 console without a disc in the disc tray.
In the System section of the Xbox Dashboard, select Console Settings.
In the Console Settings area, select Audio.
In the Audio Settings area, configure settings for analog output or digital output:
Analog output settings:
Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
Mono: Select this setting for systems that do not support stereo output.
Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
Digital output settings:
Digital Stereo: Select this setting to use digital stereo output.
Dolby Digital 5.1: Select this setting to use Dolby Digital output.
Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
You can use an HDMI-to-DVI cable for the TV's DVI input and this would give you video at full HD 1080p resolution but you need to route the audio via standard red & white RCA. It would be better if it has digital audio inputs such as optical or coaxial to get Dolby Digital and other digital formats from your source.
If in the unlikely scenario that it does not have a DVI input (which looks similar to your PC's blue VGA only wider and is white) you can hook it up to your component video-in (which is the red/blue/green RCA inputs). For this you need a cable that has HDMI on one end and red/blue/green for video RCA's +red/white RCA's audio.
This would give you 1080i resolution with stereo audio.
