Question about Safety 1st Baby Gear
Cant figure out how straps go back on carseat since I washed it? its the brown and tan high back with tilt...omgoodness I cant believe I have done this please help!!!!!!
Just the shoulder straps and the adjustment at the bottom is all I cant figure out...oh please help this is our only carseat and we go on vacation in a few days!
  • Safety 1st Master
  • 1,637 Answers
This isn't a product available in the UK so we're unable to assist with your enquiry. Could you let us know what country you're in so we can direct you to the appropriate customer care team?
Posted on Mar 02, 2013
Anonymous
SOURCE:
Anonymous
  • 58 Answers
SOURCE: car seat
Dorel Juvenile Group manufactures these car seats for under the Cosco brand. You should check out their web site.
  • Check out the recall notices and make sure your seat is not listed.
  • Register your car seat so that you are informed of any future recalls.
There does not seem to be any Manuals on their website, but they do list a phone number. 1-800-544-1108
When I did this my shoulder pieces were screwed on. I am assuming you mean where the straps go through.
Posted on Nov 16, 2007
Anonymous
SOURCE: carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Posted on Dec 01, 2007
Anonymous
  • 125 Answers
SOURCE: shoulder straps
There should be metal hooks on the backside that hook onto the loops at the end of the shoulder straps. They will definately be metal so should be easy to spot against the plastic back of the car seat. They usually are sort of rectangular and have one side that has a 'lip' so the straps aren't supposed to just slip off. (Though I can imagine the possiblity of this when the belt is not stretched as it is during use) Refer to your manual if you cannot find them. If you no longer have the manual, you should be able to locate one for downloading or viewing PDF file at the manufacturers website. Hope this helps! :)
Posted on Aug 19, 2008
Anonymous
SOURCE: trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
Posted on Apr 13, 2009
Anonymous
SOURCE: car seat straps
I have the same problem with mine. It's an easy fix. Unlock the straps (pull the little gray release tab) and then pull firmly upward on the lap belt opposite the loose strap. To reword: If your left shoulder strap is the loose one, go the right side of the seat, where the LAP belt comes out of the seat, and pull firmly upward on that part of the belt. It will pull the slack out from the other side. I hope that was helpful.
Hi. I have a Maxi-Cosi Priori SPS Car Seat which I purchased three years ago. I struggled to dismantle the straps from the seat to get the cover off in order to wash it, but I did manage it. But now I...
Good Afternoon
The harness straps should not have been completely removed from the carseat - you do not have to do this in order to remove the fabrics for washing. We cannot advise that you re-thread the harness yourself due to the safety implications of it being incorrectly done. This carseat should be sent to our engineers for them to carry out this work and for full safety checks to be done before it is used again.
If you are in the UK please contact our customer service department on 01284 413 141 Mon-Fri 8.30-4.30 and have a chat with one of the advisors about this.
Aug 21, 2011 | Maxi-Cosi Priori
The cushions was taken off because it needed to be washed, now they cannot figure how to make sure the straps are right.
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Dorel/Eddie Bauer carseat instructions:
Canada:
http://www.eddiebauer.djgusa.com/can/eng/instructions
USA:
http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Mar 16, 2010 | Eddie Bauer Deluxe High Back Booster...
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
I cant losen the tether in the back
Usually you just rotate the buckle away from the strap as you push in the release button. Every carseat is a little different so your best bet is to look in the original owner's manual. if yo do not have it, it can be downloaded from the manufacturer's website.
Aug 21, 2008 | Evenflo Chase Comfort Touch
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Carsear Straps
I believe page 3 is what ur looking for. I have done this SOO many times, they get soo dirty soo quick!! Good luck and be safe!!
http://www.elitecarseats.com/assets/product_files/instructions/Eddie-Bauer/EddieBauer_3in1_manual.pdf
Nov 01, 2007 | Eddie Bauer Deluxe Convertible
Car seat straps
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
Jun 03, 2007 | Evenflo Chase Comfort Touch
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Baby Gear Logo
105 people viewed this question
Top Safety 1st Baby Gear Experts
superdad1976
Ekse
paul
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
