Relaced all seals,o rings,impeller,and housing and pump still leaks a lot.
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
SOURCE: Installed new impeller, seal, o ring and square o
the o ring usually would not fit if it were the wrong size. What seals is a ceramic seal, did you change that? If run without water, the ceramic seal will be damaged....
