Question about Lenovo IdeaPad Z560 Notebook
Laptop z560 ideapad,starting problem,start with beeping sound
When I start ,it beep continuously ,after sometimes show loading files .....
Anonymous
SOURCE:
Harrel Abalo
  • 107 Answers
SOURCE: iam using lennovo y410 series.my lapton suddenly
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Posted on Feb 22, 2009
Anonymous
  • 162 Answers
SOURCE: getting beep sound when i
Hi. I think the problem on your machine is the RAMS if you here the beeping sound. I would suggest that you remove the memory and clean the contact points with an eraser but make sure that you remove all the receduces and also make sure that when you plug them back you should double check if they are properly seated. If you still having the same issue after doing the troubleshooting step then try a known good memory so that you could make sure that the problem is not with the memories you have.
Posted on Jun 03, 2010
Matrix12
joyson baira
  • 370 Answers
SOURCE: hi this is srinivasarao, i
Welcome to FixYa! There's a possibility that the driver is not properly installed. Please follow these steps for you to be able to make it work as long as its not a hardware issue. Please click on this link to download the latest driver for the camera.
1. Click download at the bottom of the page.
2. Click on I agree.
3. Click on Run.
4. Click on Run again.
5. Follow the download instructions. Once done, press Fn Esc on the keyboard for you to be able to disabled/enabled camera.
Hope this information will help. Thank you for using FixYa!
Posted on Mar 04, 2011
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: User guide IdeaPad Z560
You can download and print the user manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Posted on Jul 22, 2011
SOURCE: i am sunita , my
Hi
You need to go to Lenovo Ideapad Support and download the latest drivers for your computer.
http://consumersupport.lenovo.com/ot/en/driversdownloads/APR_Driver_List.aspx?CategoryID=37684,67873,633979,880973&OS=-1
Just select the Operation System your computer use and in category select all.
Hope this will help you
Posted on Aug 28, 2011
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Continuous beep at startup when loading windows files
If you mean that your computer always beeps at startup, this is a sign that everything is working as it should. This is a good thing. However, if you mean that your computer beeps continuously without stopping, and your computer does not load windows properly, you may need to use a windows disc to reinstall your operating system. If your computer still does not work, you may need to take your motherboard to your nearest pc store to have it looked at. Preferably go where you bought it.
Feb 18, 2013 | Toshiba Satellite Computers & Internet
Laptop emits continuous stream of beeps and loads advanced boot options page.
there is couple reason for that. (1) start windows normally and restore the system at previous stage. so if some driver software conflict with hardware then it solve problem. (2) insert the os disc and boot from the disc and choos repair \restore operating system. it may replace any missing system file. (3) if 1st and 2d not solve the problem then remove the RAM and clean it and fix it again. or check SMPS or Hard drive...
Jul 09, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My frigidaire GLTF2940ES3 front load washer keeps making beeping noises even when not on. I have unplugged it until using it. Seems to work somewhat but it stops in between cycles, beeps and blinks...
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Dec 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
During any cycle washer will stop and beep and flash E10. after pushing start it will continue, sometimes will do this several times in a load.
i believe that code is water related not getting enough water maybe drain hose is too far down drain and unit is siphoning
Apr 18, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Won't Start - Beep-beep-beep
unplug it then plug it back in to see if it helps
Jan 16, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Nov 07, 2008 | Acer NSK8458AN Keyboard
Lenovo IdeaPad Z560 Notebook Logo
424 people viewed this question
Top Lenovo Computers & Internet Experts
Ekse
Toby Lee
Toby Lee
Sunny Solanki
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
