Cherry Electrical T20 Mobile Logo
Posted on Aug 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Master code for t20 - Cherry Electrical T20 Mobile
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Aug 04, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
22648
Points
259
Phones codes is 12345 or 00000 u can use it
4 Digit user code: 1234 or 0000
6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Riso CV 3230 Digital Duplicator. ERROR CODE C02-253 in RISO CV 3230
Error Codes > Riso > SF5350 > Code C02 253
Printcopy.info https://printcopy.info > brand=Riso > code=C02 253
Code: C02 253 · Description: The master for the master roll has run out (or is running out). · Causes: No-master error has occurred five times on the same master ...
Missing: 3230 ‎' Show results with: 3230
Riso MZ790 error C02-253 Replace Master Roll ~
Copytechnet https://www.copytechnet.com > ... > Digital Duplicators
Dec 30, 2017 - Re: Riso MZ790 error C02-253 Replace Master Roll ~ Hold yellow reset while turning machine on, update firmware, check wire harnesses, etc...
Riso MZ series error codes T03-504 & T03-514 - Copytechnet
Jan 9, 2013
Error Code Riso CV3030 T01 - 537 error - Copytechnet
Aug 13, 2018
Recurring jam on Riso RZ 370 - Error code : J08 - 409
Jan 27, 2019
Error Code T20-437 on a RZ990 - Copytechnet
May 17, 2011
More results from www.copytechnet.com
Unlock phone zte t20
Get the ZTE unlock code as below
Unlock Your ZTE T20 go the direct link below and select your country and network
Unlock ZTE T20 How to Unlock ZTE T20
make all process done. code will be delivered you by mail
12helpful
4answers
Reset code for cherry mobile t20
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
ThinkPad T20 2647 PC Notebook: The lap top will not boot. It's a thinkpad T20...
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
13helpful
2answers
1helpful
Bios master code for ibm thinkpad T20
There is no such thing as a BIOS master code, just access your CMOS battery, remove it for a few minutes and place it back, that should be able to reset your BIOS...
IBM T20,inaccessible boot device
The Innaccessable Boot Device message means one of 2 things:
1: your hard drive has died - not much here, must replace drive.
2: The master boot record has become corrupt. Without any media, this will be hard to fix. You will need to boot to the Windows CD and either run the recovery console or perform a windows repair to fix this issue.
T20-414
Check the paper ejection unit that is a T20 code T02 code would be a standard tray lift issue.414 is not listed in the book for eather code
Ibm thinkpad t20 notebook
Could be a problem with the MBR or Master Boot Record.
It could be damaged. It's only a file system type problem not a hardware fault.
Have a look here.
http://www.ambience.sk/fdisk-master-boot-record-windows-linux-lilo-fixmbr.php
Top Cherry Electrical Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cherry Electrical Cell Phone Expert? Answer questions, earn points and help others
