Anonymous Posted on Aug 04, 2012
F2-64 on sharp AR-5318
F2 -64 error on sharp AR-5618. But the toner still not finished. And then i replaced the toner chip. after that i only made a few copies then it indicates the same error.
bhathaniya hanif
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 11, 2013
bhathaniya hanif
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12409
Points
29
Sharp ar 5618 zerox machine in f2 64 error solution
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on May 26, 2008
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Anonymous
  • Posted on Jun 17, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Sep 26, 2008
SOURCE: error f2 in copier ar 5127
F2:
00:TONER SENSOR
02:TONER SUPPLY PROBLEM
04:WRONG COUNTRY,WRONG CARTRIDGE,DRUM
05:DRUM PROBLEM,WRONG CARTRIDGE
39:PROCESS UNIT THERMISTOR PROBLEMS
58:PROCESS HUMIDITY SENSOR PROBLEM
Inno Laur
  • 93 Answers
  • Posted on Oct 16, 2008
SOURCE: crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
3answers
ERROR CODE F2-40 ON SHARP AR-5618 COPIER
using third party drum or toner replace with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
F2-64 on sharp AR-5618
replaced the toner chip or replace toner cartrig
61helpful
4answers
1helpful
3answers
How to reset sharp AR -5618
how to reset the toner chip as it is costaly
3answers
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
k24674
ADMIN Andrew
ADMIN Andrew
