I need sd card software information as mine broke and cant find anyone who has it - can anyone help? Thank you [email protected]
SOURCE: Not seeming to read SD map Data Card anymore
I have seen this before, if you turn off the unit while its saving data such as your last position or your last destination, especially if you shut it down while its still navigating. the card data can get corrupted. the only way to fix this is to reload the map data. Fine Digital is out of business so I created a DVD that has the last issue of map data and firmware for these units. you can find this dvd on ebay by searching for finedrive dvd. its way cheaper than what fine digital used to sell upgrade dvds for ( $150)
SOURCE: PLEASE INSERT THE SYSTEM SD CARD TO CONTINUE
well that stinks I had a brite blank screen and I opened it up and fixxed it but not for everyone to fix I need the dvd or card do you have the dvd as you may need to install the system software on the cards also
SOURCE: fine digital 400 not av
There is no such thing "finedrive dvd... " on ebay, please check before you post,
SOURCE: fatal application error
this is a common problem, its caused by corrupt data on the SD card. it happens when the unit is powered down while its saving data. to avoid it you want to shut down using the menu or exit navigation before shutting down.
now, you have 3 options:
Option one: Visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
Option two: The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. or C&C also offers a repair service for about $150.
Option 3 Because Fine Digtal closed their doors and left us all stranged, I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only. to find it, search ebay for finedrive dvd...
