It is a Fisher and Paykel fridge freezer upright model is a Active about 7 years old. Fridge fan replaced by a tech but did not sort problem. Could not get tech back.It has the control section at the top of the fridge with the three buttons two to make the settings warmer or colder and the third to select between the fridge or freezer sections. All settings set to cold fridge only makes the normal bleeping noise when fridge door left open. lights on controls all green. Thanks Jim
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
There is also a fan in the freezer compartment which if broken will cause this problem. you need to check that both fans are working. please refer to other fridge posts here re repairing/ replacing the freezer fan- there is a document here which shows you exactly what you need to do. important thing is to switch off the appliance first and leave the freezer door open for about 20 minutes before attempting to remove the back cover ie let it warm up first, so that you don't break any of the panels.
Your defrost timer is not working properly and needs to be replaced . They usually fail around the 5 to 7 year mark
fridge bottom working ok but freezer warm
shows fault F26 or F2b. Beeps while door is opened.Spanner symbol to call tech is displayed.The ice maker is turned off.Temp in fridge & freezer seems ok.
