Maytag model mde6700ayw neptune dryer shut off last week the clothes in it were wet and cold and hE was on the control panel so i replaced the heating element. Turned the dryer on empty for about 4 minutes and it was heating next morning we put a load in it it shut off after about 10 minutes the clothes were cold and wet and the control panel said hE. Later i ran it empty but it still doesnt heat, is something other than the element and do i need a nother element plus what ever is causing it.
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
SOURCE: maytag neptune (gas dryer) just stopped heating
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
SOURCE: Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
checked air vent it wasnt clogged
