I have an instruction manual with a brand new crystal Phillippe Starck PH-1100 but can't find anything in it that relates to this watch! I can't set the time or adjust the strap. I have a feeling I have to remove a pin from the buckle to adjust the strap but haven't a clue about setting the time!
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Thanks Arthur, finally found 2 tiny holes on strap. Upper one adjusted mode when pushed with a pin, lower one set time etc.
