I bought one used and it did not come with a manual. I really would like one since I don't know anything about the camera and my daughter doesnt either, I bought it for her
You may download a copy of the manual from here.
The first link posted by Nigel, above, works. The rest did not.
http://www.photo-manuals.com/manual/minolta/film-slr-camera/maxxum-400si
SOURCE: i don't know how to load the film in?
Hi. This might be useful
http://www.youtube.com/watch?v=lCCCLagBKg8
SOURCE: minolta maxxum 400 si
These two links have a manual that seems clear enough to read; http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part2.pdf Hope this helps - please post again if not :)
SOURCE: minolta maxxum 400 si used with opteka 500mm lens
this is due to whats called lens mount check or lens lock,
it is because the camera cannot comunicate with the lens electronicly,
to disconect the camera lock if this is the problem then
Press and hold DRIVE MODE and AV buttons while turning on camera.
this will temoreraly disable the lens lock any problems contact me
SOURCE: I need a battery for
You need one 2CR5 lithium cell for your camera. They're still available, see here for details. Note that other suppliers stock them as well, I only link to the supplier provided as they're where I buy mine and the page shows you alternative model numbers that the battery is sometimes known by.
Please take a moment to rate my answer.
Testimonial: "Great site! Answer solved my problem. thank you Guru Obertelli."
SOURCE: minolta maxxum 3000i, i need to know how to
The camera doesn't have a way to do this. If you use non-DX film, or DX film out of the camera's range, the ISO is automatically set to 100.
If you need a manual, you can download one from
http://butkus.org/chinon/minolta/minolta_3000i/minolta_3000i.htm
The film speed is discussed on page 13.
Sorry if that wasn't the answer you wanted to see, but that's the way this camera works.
Testimonial: "thank you, quick response ;)"
