Televison & Video Logo
natasha blundell Posted on Aug 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn on tv blue light comes on then when i press a button to put a channel on blue light re appears
Matsui 36in tv
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 04, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292575
Points
3377
What you see is a protection mode. Change input device to some other like a DVD player. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
5 Related Answers
Anonymous
  • Posted on Nov 02, 2008
SOURCE: when I push the power button, the blue light comes on but tv doesn't
It is the capacitor. It is really easy to fix, and it will cost you about $4. The capacitor is on the power board and it looks like a small battery. The bad capacitor will have a small bulge on the top, the good ones will be flat on top. You can buy them at Radio Shack. Just look on the side of the capacitor to see which one you will need. If you need any further info I would by glad to help. I have a 40in polaroid that this happened to and it works like a dream now.
Anonymous
  • Posted on Nov 29, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
how do i set up pip
panchal643Ja
Jayesh Panchal
  • 280 Answers
  • Posted on Jan 23, 2010
SOURCE: tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Anonymous
  • 8619 Answers
  • Posted on Apr 18, 2010
SOURCE: tv isnt coming on but is getting power
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Kenneth Lee Sr.
  • 597 Answers
  • Posted on May 31, 2010
SOURCE: my goodmans ld3265d1 tv when turned on the standby
power board defective
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Want to know how to adjust the color on my 36in ilo tv
press the menu button at the tv panel and then select preset then select color adjustment. you can use the channel up/down button to select preset menu and then to make an adjustment you can use the volume up/down button.
95helpful
2answers
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
How do i program the control to the converter box!
Try these steps: 1. Turn on your TV and change it to channel 3 or 4. 2. Press the power button on your Insignia Remote control. The converter light will be turn on in stand by mode (the red light appears). Press the power button again, the blue light will be on. 3. On your Insignia remote control, press the menu button. 4. A menu items appear, navigate to the autoscan item to scan channel.
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Matsui TVR 190 Combo VHS/ TV
in the main menu select Ch tuning by pressing PALY OR STOP then press enter.the tunig screen will appear
press F fwd and when a clear picture is found pressENTER then the number of the channel that you have found. Press ENTER to confirm the channel number. the number will stop flashing. repeat stage 2 until you have found all available channels. press MENU button to exist the menu.
Matsui tv model 32wn03a
With the TV on normal picture, no menus on
1 press and hold menu on the handset until the overview page appears
2 press menu again
3 put the cursor on channel 1
4 press and hold the button at the bottom of the remote with white around it until the tv starts tuning. Wait for it to finish.
5 hide delete insert etc the channels as you want them using the coloured buttons as shown on the screen
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
