Dell Inspiron 8600 Notebook Logo
Posted on Dec 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Quick heal though i hav installed quick heal in my laptop m not able to find it in add/remove programs to uninstall. pleaz help me .........
  • Irfan Mansuri May 11, 2010
    why "quick heal" and "kaspersky" both's web site not open ?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
755
Points
You should get I touch with their customer support they were very helpful when my av was not working....http://www.quickheal.com/submitticket/
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 23, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
628
Points
Where is the Quick heal directory in our pc
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on Feb 22, 2009
Anonymous
Expert
Level 2:
Answers
68
Questions
0
Helped
15265
Points
121
Hi
i got complete solution for that but you have to tell wich version of Quick heal you using if that is 2007 or 2008 i can help with this tooal go and download Quick Heal Removal Tool from here
click on this link you will get one removal tool for that
http://support.quickheal.com/esupport/index.php?_m=downloads&_a=viewdownload&downloaditemid=6
if you are using Quickheal 2009 version then click on the below link and get the removal tool
http://support.quickheal.com/esupport/index.php?_m=downloads&_a=viewdownload&downloaditemid=14
if still problem not cleared go to safe mode and uninstall it
bye bye
http://xviruslab.blogspot.com
Anonymous
Level 2:
  • Expert 57 Answers
  • Posted on Dec 16, 2008
Anonymous
Expert
Level 2:
Answers
57
Questions
Helped
14068
Points
117
Ok this is one of my two options since I cannot install the software to give a exact no fail answer for ya:
1) Open My Computer
2) Go to Program Files
3) Look for something called Quick Heal
4) Open that folder and then look for one of the following files:
[Note: * 's are Widcards: Meaning anything after or in place of that is fine.]
unins*.exe, uninst.exe or anything called Uninstall or like it.
If you see one run it as it will most likely work and remove it for you.
Also in some rare cases there is a Setup.exe that has the capability of removing the software as well.
My second option would be to if you can find the Quick Heal folder is to click the folder once to highlight it, Hold Shift and press Delete to permenantly delete it and then go about something that works but I warn you if you do any mistakes can cause issues:
1) Go to Start > Run
2) Then type cmd and hit enter.
3) Once you see the run Dialog type: msconfig
4) Press Enter
5) Go to the services tab and uncheck any box that in the manufacturer says Quick Heal in any means or is in the Startup Item Part.
6) Go to the Services tab and before you do anything check the "Hide all Microsoft services"
7) Look under Service and Manufacturer for things labeled Quick Heal and uncheck them
8) Click Apply and then Ok and then then the reboot option.
This process should manually remove Quick Heal but I suggest you only do this for this program.
I sincerely hope this helps.
tip
Advantages and Disadvantages of Quick Heal Antivirus
<p>Quick Heal offers a number of compelling features and the right technology to keep your PC protected. As one of the best antivirus software products reviewed, Quick Heal offers a great solution that delivers advanced protection and simple use. But apart from this Quick Heal have some advantages and Disadvantages.<br /> <p> <br /> <p>Advantages :- As per users review Quick Heal stopped viruses the others missed completely, When a virus is detected it is taken care of without halting the system, There is absolutely no noticeable slowdown in system performance and I have not had a problem installing any new software because the virus scanner was enabled. The software support team is quick to respond anytime you have a question or concern. It is much more user friendly and every bit is better.<br /> <p><span></span> <br /> <p>Quick Heal provides PC Utility software like PC tune up to boost up your pc, with that tool you will get Disk Cleanup - to clean unwanted files and short cuts, Registry Cleanup - unused keys that often left after software uninstallation, and Disk Defragmenter, etc.<br /> <p> <br /> <p>Quick Heal Anti-Virus is easy to download and install. The installation is straightforward and doesn't require a restart. And while it's not the fastest, it's relatively quick and performs an update immediately.<br /> <p> <br /> <p> <br /> <p>Disadvantages: - the main disadvantage with the latest version of Quick Heal protection software is, if you are using free version of that version, then it will provide limited protection, to avail full protection you should have to register it online or have to buy a registered version.
How do i surrender my quick heal total security?
If you mean that you do not want to use it any longer, go to Control Panel, then Programs and uninstall it.
2answers
Sir how to reinstall quickheal trial version we always use trial version for 30 days before 30 days we are delete old version and use the new one trial version for next 30 days but now i have install 11.00...
Hiii
May be you u cross the trial version limit ( Some company provide the 3 time use the trial version) now purchase the license, other option u have to format your computer but its not recommended.
Good Luck
When i first install quick heal total security 2010 trial version & remove after use 28 day .....so now i m install quick heal total security 2011 but not install it says ur all ready use trial version...
While I am not familiar with this particular security suite I did peruse their website. While they are obviously not a major player the product they offer appears to be legit.
The first thing that comes to mind if installing the full version ends up appearing to be the trial version is that the uninstaller -- you state you removed the trial after 28 days -- had an issue and left remnants of the trail version (registry entries etc). This is a common problem.
My suggestion is to do a complete uninstall of the security suite with a highly recommended program called Revo Uninstaller. I don\'t **** a whole lot of products, but this one makes my short list. You can get it here:
http://tinyurl.com/64tsr5b
The other thing to check is whether there is an option within the program to enter the serial number for the full version of the security suite in order to switch it from trial mode to running as fully licensed mode.
1helpful
Good evening sir, I am the student of B.tech. computer science from up technical university, India.I have my laptop of toshiba company.and I have installed quik heal anti virus software.but my quick heal...
I Hate Quick Heal its a waste anti virus . To make your computer perfectly alright you have to download this two tools
1. Combo Fix (Which Removes Malware Instantaneouly)
Click Here to Download
2. A Good Antivirus Software Like Avast Which is Free And Best Try it.
Note Befor Downloading unistall the quick heal from add/remove program . Then first run combo fix then install avast
Enjoyyyyyyyyyyyyyyyyy
4helpful
2answers
Unable to install quick heal total security 2009
Go Start > control panel > add/remove programs and uninstall it.
Why pay for a security software when you get a top rated one free from Comodo?
Got to :
http://personalfirewall.comodo.com/download_firewall.html
And click on the green download button.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Not able to install any Antiviris except Quick Heal
Hi shyjuu, please open the link below at Quick Heal & follow their instructions to uninstall the antivirus software. Click on this link: http://www.quickheal.co.in/installation-uninstallation.asp
Once the software program has been removed restart your system. Than go to this next link & download & install RegCure for free.
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
This is a free download & will remove any & all none needed registry keys within you windows registry.
When finished, restart your system. Next download & install AVG version 8.0 free antivirus software to help keep your system safe: http://free.avg.com/download?prd=afe
Or install the antivirus software of your choice.
Good luck shyjuu!
Mike
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
