My canon ir2016j close left front cover
SOURCE: How can i solve this errorcord eoo7 canon IR2016J
1. Check fixing film sensor.
2. Check fixing film sensor connector.
3. Check fixing film.
SOURCE: usb to not detect ir2016j canon xerox machine
Usb to not detect ir2016j canon xerox machine.
SOURCE: Hello i want the canon IR2016J printer driver to
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay yhjka
SOURCE: Sir I have canon IR2016J
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
