Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
jenny Posted on Aug 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 3 panasonic RR930 w/ different problems, won't erase tapes, the back space doesnt work and one will not play. where can i send them for repair
Dictation Mall
Level 2:
  • Expert 145 Answers
  • Posted on Aug 11, 2012
Dictation Mall
Expert
Level 2:
Answers
145
Questions
0
Helped
54536
Points
173
Send to Dictationmall. 866-321-9780
1 Related Answer
Dictation Mall
  • 145 Answers
  • Posted on Aug 02, 2011
SOURCE: Panasonic Model RR-930. The machine will not
Check that the pause switch is off. Otherwise, either the belt is broken or the motor is bab.
Testimonial: "Thanx so much. I was in a rush to get a job done and didn't realize that I pushed the PAUSE button..."
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
New DCR-TRV260 won't play my old tapes
I have the same problem. I just bought a sony handyman and tried to play my old tapes and nothing, not even sound. But I just recorded something using an old tape and it records and I can play that back. I'm thinking maybe over time, somehow all the data on there got erased. Which is really a bummer.
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Cant playback tape
Videos recorded on one camcorder very seldom play back in another, due to the internal codes put on the tape by the original machine.
I have a tape which I'm anxious to play to convert to a CD, but it just won't play ! It will fast wind both ways but on play just shuts off. (It hasn't been played for a long time) It does...
If you wind the tape by hand (with a pencil or screw driver etc.)is the tape easy to turn or move from one end to the other with out any binds? If not It may be wound unevenly, smacking it down on a flat surface a few times on each side will usually free it up. Hope this helps.
1helpful
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Help!! No playback!!
First try a cleaning tape, if that doesnt work it most likely the tape path is out of alignment and you will have to send it in for repair.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
