... and owner manual. From smoke free house Thanks for your interest. ... 2 Glass Mixing Bowls Large & Small for West Bend mixer 41036. $24.25. + shipping.
US$35.00 · ‎In stock
Does the bowl table rotate freely by hand? If not, it may need a squirt of spray lubricant. If the table rotates freely by hand but doesn't turn when mixing, look at the bottom of your beaters. The beater that is closer to the outside should have a nylon button at the bottom. This nylon button rotates the bowl as it turns. If the button is worn or missing, you will need to get new beaters.
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
Sorry to say, the part is no longer available from the Sears parts site, and no substitute exists. Unless you can find a bowl from some other brand and model, or just a suitably-sized mixing bowl, you're out of luck.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
You need to raise the bowl just a little less than the thickness of the layer presently being left behind. Too much and the beaters will touch the bowl .
