The inside illumination lamp is not working
SOURCE: Daewoo KOC-985T - Help me find manual!
if you still havent got one i can photocopy mine if its any use
SOURCE: Daewoo KOC-1B0K no interior light and turntable not rotating
Looking at the service manual at our site, that would be a failure in the "motor relay" (relay 4) or one of the components that drive that relay, such as transistor Q8.
The part numbers for this relay are OJ-SS-124LM (generic) 5SC0101405 (Daeweoo).
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Where can I get a users manual for a daewoo
manual required for a daewoo microwave cooker model no. koc-8h4t
SOURCE: micro wave works but do not heat up the contens
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode
and capacitors can br tested. The capacitor must bealloweddischarge
before testing, or you risk to get electrocuted, evenifpower is off.
Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
SOURCE: how do i change the bulb lamp on a Daewoo KOC-875TSL microwave
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
If you don't have your
instructions, please reply back with your brand and model number.
Once it's out of the
wall, the outer cover (wrapper) will need to be removed, just as you'll
need to do on a counter top model.
On a
counter top model,
be sure it's unplugged, but otherwise ignore the instructions
above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
