It's also not leaking from the back of the tub spout
There may be some leakage in pipe.Take the help of experts.Nowadays there are many leak detection services that can help in solving such problems.
find a leak in wall
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
SOURCE: Just got the tub faucet fixed from leaking now the
If its a balanced pressure shower then you most likely have installed the cartridge wrong. Remove the trim plates and rotate cartridge 90 degrees clockwise and re-istall trim plates
SOURCE: Can you actually remove a diverter from the spout
No often the problem is that the metal deteriorates inside of the spout...
Replace the whole spout... it will either spin off or there will be a small setscrew underneath at the back and then it will pull off...a new one is not that exspensive...
heatman101
SOURCE: Hi , i have a
You can take the part to your local Ace or True Value hardware store or Home depot or Lowe's and find something close that will work. Bring the whole part with you. Buy a few sizes that or close just in case, they are very inexpensive.
Thanks for using FixYa
If you are saying that water is still coming out of the tub spout while the shower is on that is not a big deal a rather normal. If it bothers you a lot then you will need to replace the tub spout as the diverter in the spout has gone bad or is going bad.
Now if you are saying that the shower is leaking behind the wall when the shower head is being used then the threaded joint at the shower head arm is leaking and will need to be undone and put new pipe dope on the threads and reinstall it or it may be just lose and if that is the case remove it and reinstall it anyway.
If the water is leaking behind the wall and the above is not the case you will need to get into the wall and see where the leak is coming from and take the necessary steps to fix it.
Hope this helps and good luck.
It doesn't leak when water is running into bathtub only when using the shower
