GE Advantium 120 Convection/Microwave Oven Logo
Mark Klein Posted on Mar 19, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sca2001bss03-Advantium oven-built 06/2000
Black fan button is beginning to malfunction. Can press on, then difficulty turning off or changing speeds. I have to apply different pressures to different points on the button to make it change. Afraid that very soon the button will stay in the "on" position. Also, is their any diagrams/instructional help to get at the brain to work on it. I am electrical savvy, this unit is installed into the cabs above the stovetop....Help please.
  • mrshamus Jun 17, 2008
    The micro wave portion of the oven made a loud buzzing noise then stopped working. Also the square cover on the right inner side of the oven was arching just prior to failure. The oven is about 8-10 years old. Any suggestions? Thank Dave H.
Ticketfish
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2008
Ticketfish
Contributor
Level 1:
Answers
Questions
0
Helped
617
Points
Can you change out the front/color of the advantium above cooktop ovens from almond to stainless
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Mar 20, 2007
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4481118
Points
21747
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts (such as "button") by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you find you need control panel repair, we do that nationwide for $39.95 in most cases. See: http://tinyurl.com/yzjozk
AUTO VENT FAN WONT TURN OFF
Generlly uWave oven fans have sevealr speeds. They are accomplished with an electronci speed control device in the form of a "Triac." That is a solid-state device that can fail sorted, which means the fan will run continuously on "high." It means the uWave oven needs a new controller, which will be expensive.
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
1helpful
GE advantium SCA2001BSS03 need owners manual
Yes, here.
The renter threw the tray to adapt the microwave to convection oven. I need to know where and how much a new one costs?
Are you talking about the black round pan? I don't think I have any other parts in my Advantium for speed cooking or convection. I occasionally just use an oven safe dinner plate. Sorry I can't help with replacement parts.
7helpful
How do I unlock the control panel
If this is a GE Advantium series microwave, the control panel can be locked to prevent children from manipulating the controls. To lock or unlock, press and hold the CLEAR/OFF button for 5 seconds. These instructions are included on page 36 of the owner's manual listed here:
http://www.managemylife.com/mmh/owner_manuals/14895/GE-Built-In-Microwave-Oven-L0902200?brand_name_search=+GE+Advantium+120
If you have questions, please post back and let me know. Please include your MODEL NUMBER if diffrent form the model you posted this question under. I hope this helps you.
Power level
Hi cindeet,
I don't have this particular model, but have experience with other GE stoves & ovens. Looking at the control panel for an Advantium 120 at the link below,
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
I'd start by pressing the "Power/Temp" button, and then turn the knob to select which power level.
There is also a Help menu shown (upper left corner of the photo I'm looking at - page 4 of the PDF document referenced above.
Let me know how this works for you - thanks in-advance.
Jon
2answers
Cooling fan diagnosis GE JVM1443WK
hi firned
u have to fined the same fan of your oven & replace it if u not have idea to change it then go with a good techinision of oven
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
