Panasonic KX-TA824PK Phone Logo
Sandy Posted on Aug 02, 2012
Set auto for DSS - Panasonic KX-TA824PK Phone
Olga Maria Miyares
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 25, 2014
Olga Maria Miyares
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
1027
Points
5
First set your DSS in program 003, then pair it with your phone in program 004, then check program 005 to assigng one touch transfer.
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
1helpful
I have the Olympus DSS 5000 transcriber how do I set the footpedal to automatically rewind a small amount when I take my foot off the pedal
Go to tools, then options. Click on thr User Settings tab. Click on Playback control. You will now see auto backspace at the top right of that page.
Good Luckdictationmall
I cannot get sound from my sony tv (ldl 40bx420) to play through my strdh520 .....my blue ray sony bdp s580 sends a nice signal through it to the speakers.....I have tried every tip in the manual to try to...
Depends on your sources and connections. If you have Cable Box, DSS, FIOS, etc. Audio would be from Coaxial or Digital Optical from the respective source. You would need to check the Audio settings on the Cable Box, DSS, etc. If you are using Cable or off-air, direct from the TV, it would be connected from the analog audio (rca) or Digital Optical output from the TV and The Audio out setting on the TV should be set to Fixed. On the Sony Receiver, make sure all inputs in settings menu for audio are set to auto. Hope this helps, if you still have a problem, post a reply/comment with any other equipment you have connected between TV & Receiver
WHAT IS A DSS KEY?
DSS is a term for Direct Station Select.
In Panasonic, a DSS console is separate from the phone and some system functions can only be programmed on a DSS key. You can program some buttons to Directly Select Extensions, but they only select extensions and can't be used to replace DSS keys.
Yeah, I know it's confusing, but that's the nature of Panasonic. Other systems have DSS keys also and use that term.
Carl
I have a marantz sr7200 receiver and i am unable to get sound when its in DSS mode. The sound works in dvd and tuner modes.
In the setup menu, did you set up the input assignments for DSS to be the correct digital input or analog?
My taskbar wont work and the message team H20 CLEDEX has stopped working appears, how do i fix it without resetting to factory settings
Greetings,
To fix the issue please download Deckard's System Scanner (DSS) and save it to your Desktop.
  • Close all other windows before proceeding.
  • Double-click on dss.exe and follow the prompts.
  • When it has finished, dss will open two Notepads main.txt and extra.txt -- please copy (CTRL+A and then CTRL+C) and paste (CTRL+V) the contents of main.txt and extra.txt in your next reply.
Regards,
TechSup1
Download device
The easiest way to correct that is to uninstall and reinstall the DSS player software. Before you go so far though, open DSS Player and go to Tools then Options and make sure the Auto download option is checked. If the option is checked but not working just uninstall and reinstall to reset the drive associations.
D-link dss-5 setup (please help!)
you need to make sure that DHCP is enabled in the router settings and that your network cards TCP/IP is set to obtain an ip address automatically.
Also check that your computers workgroup is the same as your friends eg, Home or Workgroup.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
