Washing Machines Logo
Anonymous Posted on Aug 01, 2012
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
  • Anonymous Aug 01, 2012
    Just to add this is the first use of machine?!
ernesto cuadra
Level 3:
Top Expert:
  • Washing Mach... Master 12,223 Answers
  • Posted on Aug 02, 2012
ernesto cuadra
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080029
Points
34431
See the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
beko WMP652W washing machine will start cycle but  - 8_2_2012_12_47_51_pm.gif
5 Related Answers
carsija
  • Posted on Jun 24, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Anonymous
  • 185 Answers
  • Posted on Mar 25, 2008
SOURCE: Brandt washing machine gets stuck at rinse
check the coupler it might be the timer
Anonymous
  • 9 Answers
  • Posted on Apr 20, 2009
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Anonymous
  • 228 Answers
  • Posted on Aug 12, 2009
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Anonymous
  • 41 Answers
  • Posted on Jan 09, 2010
SOURCE: Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
1helpful
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
3helpful
2answers
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
3helpful
Programme gets stuck on wash cycle
Most likely a defective door switch.
Top Washing Machines Experts
john h
