Have a sprint control panel for the cf-52 wireless connection. will often lose connectivity for no apparent reason. Even while sitting stationary.
SOURCE: wireless connection :S CF 28
control panel network connections
right click if you see Enable click it
if you do not see it then click repair.
To help you better I need to know more about the problem
SOURCE: While traveling I bent the left hinge for the lid
I'll try to hunt down a schematic for you......
SOURCE: where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
1 Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or
SOURCE: my cf 51 indicates that my wireless connection and
yes eithernet card has either lost drivers or is faulty
