SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
SOURCE: y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
SOURCE: I have changed out the
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
