The base phone says need ac power and the the cordless phone saysout of range or no power at base phone
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base
also keeps a record of how many handsets are registered to it.
Using
the de-register function on the handset deletes the handset from the
base (decrements the count) and deletes the base info from the handset.
All this requires that the base and handset can communicate with each
other.
To remove the base data from a handset when out of range
of the base, press and hold the ‘end’ button and the ‘#’ button
simultaneously until the phone beeps. It will now be de-registered from
the base.
However, the base will still have this handset in it’s record.
To
de-register all handsets from the base, remove power and the base
handset. Press and hold the ‘flash/find hs’ button while applying
power. Wait for the beep and release the button. The charge light will
now flash. Sit any handset in the cradle. When the flashing stops, all
handsets are inhibited from connecting.
However, the handset
still appears to be connected to the base unit. Pressing talk will give
an ‘Unable to connect’ message. To re-register the handsets to the
base, you have to de-register the handset first with the two button
method.
Of interest, pressing ‘*’ and ‘#’ on the handset while
reconnecting the battery is suppose to reset the handset. Doing the
same on the base unit puts you in some sort of diagnostic mode. Press
speaker to exit.
SOURCE: Range extender for cordless phone
Ours behave similarly. The solution is to position the "base" (one connected to the phone lkine physically) in the center of the home so that the limited range can reach the remote phones at the periphery.
These phones operate at 1.9GHz. At that microwave frequency radio signals do not penetrate walls and floors very well. 2.4 GHz phones suffer increased "path loss" and are no better. The solution for any of these microwave phones is more transmitter power, which is illegal.
900 mHz phones actually work better because at 900 MHz nature offers less signal path loss", but try to find them in stores! For the same transmitter power level a 900MHz phones will have noticeably greater range.
The 1.9GHz D.E.C.T. phones also operate differently from other types of cordless phones and I believe that also contributes to dropped calls and the phone's inability to ring when a call arrives. At the fringe of its range you can see how it struggles to establish a link. Once established it will work well and then simply drop the call when you least expect. I am not a fan of the DECT phones, but they do not interfere with 2.4 GHz wireless routers, etc.
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
