Ricoh AC104 All-In-One Laser Printer Logo
Posted on Dec 15, 2008
Receiving fax but not printing ricoh ac104
The screen shows that the Ricoh AC104 recieving faxes but it is not printing.
  • awalji Jan 23, 2009
    Thanks for the info. The problem has been resolved. The telephone guys had crossed the lines in that sending out was fine but the receiving fax was different line.
Anonymous
Level 1:
New Friend:
  • Contributor 58 Answers
  • Posted on Jan 23, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
58
Questions
0
Helped
52927
Points
87
  1. check paper
  2. check modem, rj 45 may be in wrong slot, must be in "line" not "tel"
There are no error codes????
http://www.websitetoolbox.com/mb/copierquestions
How do I change the setting in order to use fax on voip line?
Hi
The data transmitted during a voice call and a fax transmission are converted to digital pulses in the same way, so sending is not the problem. The problem is at the receiving end. A receiving fax device has to be set to pick up the call before the voice call device, as it is the prompt of the fax transmission signal that makes the receiving fax switch from send or idle to receive mode.
So, if you are faxing over the internet the intended recipient's setup is a complicating factor.
Since faxing to landline fax machines via VOIP would incur a charge, you might consider a cheaper software solution such as eFax (www.efax.com), which enables the receiver to receive the fax as a PDF document attached to an e-mail.
I hope this helps
Our Ricoh 1800l has stopped recieving faxes how do I fix this?
our Ricoh 1800l has stopped recieving faxes how do I fix this
Mi copiadora es una ricoh oficio1022s/p y marca un error sc390
TD sensor error
Symptom: The TD sensor outputs less than 0.5V
or more than 4.0V 10 times
consecutively during copying.
Possible Cause: • TD sensor abnormal
• Poor connection of the PCU
How can i determine the number of pages can a laser printer cartridge can print?
You can't. Depends on the quality of prints and how many copies you use. You have to test the first time putting a start date and then compare. Some programs allow you to count how many pages you printed. That would be an alternative more accurate
My fax has to "warm up" every time I print or copy something, it seems as though it is taking way too much time
yes it takes too long to do this. this is a result or goverment polices, energy star rating. you can not resolve this.
Scanner locked
Disconnect the printer and leave scanner cover open (when printer is disconnected.) When connecting printer after 10 minutes shut the scanner cover before turning the printer back on and putting the plugs back in.
The machine still show the toner empty, new toner in
this problem is mostly reported when you refill the toner incorrectly.
flush out the whole toner(not with water) just shake it upside down.
now refill it.
if it doesnt work try cleaning the terminals of toner catridge and the terminal of the printer
No fax tone giving if this fax mode only
Using "on hook" you should hear a dial tone, if you have one then dial a known good fax number. It could also be in manual receive mode. -Carl
Rocoh ac104 toner reset
I believe it has a 'quick blow' fuse on the front, left side, that needs to be replaced to reset toner counter.
2helpful
2answers
CRU Fuse Error
you need to replace the toner cartridge and or the fuse on the toner cartridge
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
