Question about Linksys WRT160N Wireless Router
Device password???? I do not know if my Eng;lish will be correct but I hope you'll understand: we installed wireless G WRT54G2 and when I try to find the connection on my laptop ( WI-fi protected setup wisard), it tells me : enter your device ownership password. I found many numbers on the box we purshased and it, is not working. Alphabetical is not accepted and I do not have the sign «Next» Thanks' for your help, Suzie
  • 1 more comment
  • Dell Owner Jan 04, 2009
    I have the same problem. The "Device Ownership Password" is numeric only and is limited to 8 characters? I set up the router and have no idea what the DOP is? Does anyone know?
  • Anonymous May 11, 2010
    When you setup the router, did you not set a admin password?
    /Teis
  • Anonymous Mar 25, 2014
    wi-fi protected setup wizard doesnt allow me to type my password
Device ownership password:
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Posted on Dec 17, 2008
I have a Dell and have used it all over the world and until I purchased a new Linksys WRT310N wireless router, I had no problems. With this new router I am asked to input a "device ownership" password. There are two ways, at least, to fix this. One, is to tell the Intel wireless NIC to stop asking for this information, the other is to give it what it wants.
Option 1.
On the PC open the control panel (these are XP instructions), open add/remove programs, find "Intel PROSet/Wireless Software" and click on Change/Remove. When the installer opens, select "Modify." When the modify window opens, you're looking for "WiFi protected setup" and you want to chose the "do not install" option. This will remove the pesky feature after hit "modify" and then reboot.
Option 2.
Use the feature as intended. Log into the router. Goto wireless->basic wireless settings and make sure WiFi Protected Setup radio button is seleted. Instructions are displayed. You want to look at item 3. The password you're looking for is there. Entering this password on your PC when asked to do so during network connection should solve the problem. This is theoretical because I chose option 1.
tr
Posted on Jun 10, 2009
    New Friend:
Thank you Trolon! Option 1 worked! :D
Posted on Mar 11, 2013
  • 41 Answers
Hi Suzie
If you haven;t setup up anything yet
The normal should be
username admin
password admin or linksys
If this doesn't help let me know I'm trying to download the manual now
Regards
Go-Tech
Posted on Dec 15, 2008
6ya staff
SOURCE:
I lost my cd of wrt54g2 v1 how i can install in my laptop
You don't need any kind of installation CD. Just open your wireless connection manager on the OS you're using in your laptop and connect to your wireless network.
If you need to configure the router, go to 192.168.1.1 in your web browser to open the router's configuration page.
Nov 04, 2010 | Linksys WRT54G2 Wireless Router
My camera is built in dont know how to work it what buttons do i press to get started
We need to know the laptop model to be able to help
I have a Sony and the manual is in the software > Start > Computer >> Local Disk (C) >> Documentation >> Eng(lish)
Aug 20, 2010 | Logitech Webcam
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
Upgrade Linksys WRT54G2 firmware failed.
there are 3 variants of the WRT54G2 , v1, v3 and v5 ensure that you choose the right firmware for the variant(its on the bottom of the router)
Go to the US site as this has more uptodate versions of the firmware.
For example v1 in the UK is at 1.0.0.0 dated 2008
v1 from the US site is 1.0.0.4 dated 2009
Jan 25, 2010 | Linksys WRT54G2 Wireless Router
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
Hi, im geraldine and i forgot my password in linksys router
Hi Geraldine
If you have forgotten your wireless password follow these steps from a wired computer
1>Start->Run->CMD->Ipconfig
2>You'll find default gateway
3>Type only the numbers on your browser window or type in eg:: http://192.168.1.1 in the run window
4>You"ll see a router setup page opening up
5>On the left hand side under wireless you"ll see security
6> Click on that you"ll see a 10 digit or 26 digit no if it wep security or a password if it is wpa .
7> that would be your security key for wireless
Mar 02, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless connection to router not working
have you pushed the wireless activation button that will detect you wireless card in your laptop. make sure you do that and hopefully it will detect it
Feb 09, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WRT160N Wireless Router  Logo
8,422 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
