Hitachi DZ-MV230A DVD Camcorder Logo
barrie Posted on Oct 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It doesnt work
Hope someone can help.
when i insert a new disc it ejects - put it back in and it asks to format disc - can't get past this screen.
that was the 1st symptom..followed the instructions to do a system reset and none of the buttons appear to be working
am i missing something ? (apart from the brain cells)
Rommel Balcita
Level 3:
  • Master 749 Answers
  • Posted on Oct 27, 2017
Rommel Balcita
Master
Level 3:
Answers
749
Questions
Helped
376956
Points
2156
The disc type is not correct, cd or dvd or blu ray or cdrw. The new disc in not empty for burning or its not empty.
Worst, the laser head is busted, it can't read disc inserted so it ejects thinking it is reading the other side but not.
please vote. thanks.
1 Related Answer
Anonymous
  • Posted on Jan 25, 2009
SOURCE: Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
4helpful
2answers
How to fix rsod in pcsx2 0.9.7
The infamous Red Screen of Desk -- A.K.A. Insert a Format Disc screen.
This screen is NOT asking for a disc to FORMAT the PS2. What it IS asking for is a PS2 or Playstation format [or a better word -- PS2 or Playstation TYPE disc. A disk with Playstation 1 or Playstation 2 type software on it -- in other words, a ps1 or ps2 game]. It's basically asking for a CD or DVD with software that the playstation can play. This red screen occurs when you insert an XBOX game or a burned/copied PS2 or PS1 game. What the PS2 is stating is that is cannot play this format [or type of] disc. It's asking you to insert a format [or type of] disc that it can recognize and use.
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. I don't install or sell mod chips, so I can't help you with that one...
1helpful
2answers
I put in a disc. it says reading then goes back to open tray. Help me.
The most common reason for the Console saying reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Console including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Console going again!
Hope it works...
My built-in dvd will not work.
hello,
The most common reason for the system not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your system including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your system going again!
Hope this will help....
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Screen locks shows open tray
keep ejecting and inserting disc...if it doesnt work after 20 or so times, buy a new disc drive of the same model
Disc won't eject from the console
Uhh...thats weird. My options are to turn off the wii and turning it back on to see what happens and if it doesnt read still, then try taking it out. Another way is to keep clicking the eject button till it comes out. Hope that helps.
3answers
Burning music from itunes
this is just itunes its perfectly normal
2answers
Ps2 game i got from englan(pal) wont play in my system here .
If you are in North America, you PS2 will not play PAL formatted disks. (NTSC is what is used here). You would need a modded PS2 to play the game. If you can get your money back, I would recommend that. If not, then you might want to try to sell it on eBay.
2helpful
6answers
Cd ejects
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Top Hitachi Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
