At first it turned on but then i shut it off then when i tryed to turn it back on noo light appeared then i charged it then the light turned on but then it shut off then i gave it another try but it did the same thing but now it wont turn on at all the only light that appears is when i plug it in but it only stays on for a few seconds
Hi there.
this is all i can find on the hip street bluetooth so not sure if this link will help you out,but have a look.
how to hipstreet bluetooth 2 0 to turn on Google Search
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
SOURCE: charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
SOURCE: charging bluetooth
hi sir..
please do u have muiltimeter just verify whether the voltage is there ..
SOURCE: My insignia bluetooth headset will not turn off
Plug the power adapter into the headset. Then press the Volume up and down buttons (+ and -) on the headset simultaneously. This will reset the device.
