Use the "Video system" command in the Setup-2 menu to switch the video output between NTSC and PAL. This is for playing back your still photos on a TV.
If you're asking how to switch the 400D into video recording mode, the 400D doesn't record video. Sorry if that wasn't the answer you wanted to see, but that's the way it is.
Then how can get the 500D
SOURCE: canon eos 400d mode dial does not select modes
Looks like you need to take this to a camera store and have them check it over. I don't know of any setting that would cause what you describe.
SOURCE: How do i switch off flash in canon eos 400d
Your camera has a built-in flash and it will pop up automatically in low light or backlit conditions if you are in Basic Zone.
All you have to do is push it back down.
If you set your camera option to P, only the shutter speed and aperture are set. You can then change settings for your flash and other functions.
SOURCE: 400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
SOURCE: how do you get to the video mode on the canon 400d
There is no video mode on the Xti. The first Canon Digital Rebel to be equipped with video was the T1i, which came out almost 5 years later (2 years ago).
SOURCE: how to switch video mode on canon eos 350d
I doubt about your camera having a Video mode. However you can check these settings for your Camera in detail.
Click on the link -> Camera Settings
Regards,
Suhail
