Printer error. Turn off the printer, and then turn it back on again after a moment. If the same error occurs, turn off the printer, then contact the store where you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms. Error Code: E100 0000
Http://fix-your-printer.blogspot.in/2009/03/canon-lbp2900-error-code-e100-0000.html
Error code E#100, ERR 100 or E100-0000 is a laser scanner unit error.
Solution 1:
Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
Flip open the top of the printer.
Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
After you move the laser, unplug the printer for a few minutes.
Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative.
for other more help visit https://cbrtechsolutions.net
Le contacte de boit laser se trouve au couvert de l'imprimante ou la boit laser ne fonctionne pas
SOURCE: Laser scanner unit error. Turn off
Your laser unit is faulty. Its more cost-effective to buy new printer. Having it repaired will cost about same as a new one. If still under warranty then just return and have it replaced.
Regards,
