I replaced anew fuser unit but the printer says replace anew one. Why & what should I do?
SOURCE: Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
SOURCE: Replace Fuser Reset
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
SOURCE: Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
SOURCE: need to reset the fuser counter
Hi there.
Download Service Manual here: http://nodevice.com/manual/Konica_Minolta_QMS_magicolor_7300_Service_Manualpdf/get690.html
and follow the instructions.
Regards.
SOURCE: hp laserjet p2055dn Replace fuser unit
That is a job by it self. If you don't want to damage your printer, I'd suggest you take it to an HP dealer pay some money and get it first checked and if so be the case that it has to change, let them change it.
