SOURCE: 1991 geo prizm, battery light
Yes, it could be. Or you can check your battery. And try adding brake fluid to your master cylinder. That sometimes will cause the brake light to come on. Or check your emergency brake. Hope this helps, James Booth.
SOURCE: dash lights, dome lights and stereo quit workign when installing
YOU HOOKED THE GROUND FOR THE RADIO TO THE WIRE FOR RADIO LIGHT FROM THE FACTORY UNIT. THAT WIRE IS DRAK BROWN AND WILL SHOW AS A GROUND UNTIL YOU TURN ON THE LIGHTS. YOUR FUSE FOR PARKING LIGHTS WILL ALSO BE BLOWN. I DID THIS AND FIXED IT ALSO.
SOURCE: 1993 Geo Prizm turn signals
You have a bad turn signal switch if the hazards work and the turn signals do not. It has nothing to do with the fuse or the flasher unit. Your switch is bad or you have a bad connection some where.
SOURCE: My '97 Geo Metro LSi will not start. When I turn
It could be the starter, test the small wire going to the starter, it should have power when turning the key to start/crank. If it does, and the starter will not crank the engine, whack it with a hammer, if it then starts, replace the starter. If there is no power to the starter, then it could be the ignition switch, or the neutral switch, or a fuse/link blown.
