My dell dimension 3000 will not turn on. it's like its not plugged in but it is and there is power to the power source. I use a surge protector incase of power surges. It was working fine. just all of a sudden it will not turn on.
SOURCE: computer wont start and is
Its not the surge protector problem.
1. Starting your computer press the F8 function key
2. Select Safe Mode
3. Select the restore point and restore the last updations you had done by selecting the date
4. Wait for a time to get confirmation
5. It will restarts the system.
If the above steps are not worked you need to re-install the OS
Let me know that your problem is solved and rate me as fixya!
SOURCE: computer won't power on(my daughter's)
Your fuse probably turned off on you since you were using too much power. go outside your house and there should be a fuse box and flip the switch to the room where your computer is located
SOURCE: Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
SOURCE: I have a Dell Dimension DV051 tells me your modem
But you telephone line might be connected to ur modem??
chk for any burnt mark on modem or run modem diag that is an tool send by dell to chk ur modem
I've tried the computer using different outlets but have the same problem. I'm using a surge protector and the computer was the only item connected to the surge protector that is having a problem. We did have a storm recently.
Thanks, I'm doing some research on how to test the PSU. Any suggestions or recommendations?
