Sony Ericsson W800i Cellular Phone Logo
Posted on Dec 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone stucks. So i need to reset it by connecting to pc. can u help
Anonymous
Level 2:
  • Expert 112 Answers
  • Posted on Dec 15, 2008
Anonymous
Expert
Level 2:
Answers
112
Questions
Helped
29167
Points
259
if you know the password of your cell then go to stings and hit up the restore all data it will ask you for password enter pass cell will be restart ofther restart your cell totally format and reset.
I have an iPhone 5c and I took a screenshot on YouTube and now my phone is stuck on white screen I tried resetting it.Someone please help!!?!!
connect to pc using usb and then press the power key and the home button together and hold it until you see the usb picture on iPhone. Once its there disconnect usb and try restarting it.
Oct 19, 2014 • Cell Phones
Purchased a mobile phone "hsv 708! " it is stuck in "emergency need help to clear
Try master reset the phone and power shock it was well will help you..
AK
How do I get my iphone5 off of the connect to itunes screen and delete the update
Download TinyUmbrella and use the "exit from recovery" option. Make sure you are using an Apple certified cord always when syncing or updating your phone.
Galaxy s2 stuck on boot screen wont reset
This is an android phone, not a camera. Posting this query in a more appropriate forum may help.
2answers
My ericsson w705 turns on but when the main screen comes it gets stuck and keeps restarting itself.. and the signals symbol comes blank.. ive tried my sim in another phone, it works. also my phone connects...
Usually this means the memory is full or there is a conflict with something you have installed on the phone. Have you tried to master reset? If you can connect the device to your laptop; save pics things you need and reset the device.
1helpful
2answers
My iphone 3GS is stuck at the Apple screen. I've tried holding the off and home buttons to reset, but it's not working
This is not a good sign and one of the most common causes with this device. I could tell you a series of troubleshoot.If that would not work, device needs to be send for repair.
Have you tried a hard reset? Hold the Home and Sleep buttons together for 10-15 seconds, until you see the Apple logo come up on the screen. You may need to do this while the phone is plugged into it's charger or a computer, so that it has power.
Usually If it's stuck at that screen, and holding the buttons together for 10-15 seconds didn't help, then there's a hardware issue, and it will need to be replaced.
However, try few more steps
1. Connect to iTunes via USB. Do not disconnect for rest of these steps. iTunes may appear frozen or stuck with spinning beachball....this is okay, do not Force Quit iTunes. I tried a few times w/o it being connected to iTunes and it doesn't work.
2. Once connected, hold Home + Power until screen blinks then Apple logo comes back up.
3. Wait until Apple logo dims slightly (~5 minutes or less). Do NOT reboot until the apple logo dims.
4. Hold Home + Power again until it reboots and Apple logo comes back up.
5. After 2 min or so, the phone may vibrate once or twice. Continue waiting for the full 5 min until Apple logo dims slightly. iTunes at this stage MAY recognize the phone...do not sync or do anything in iTunes.
6. Hold Home + Power for the 3rd time until it reboots. Phone may vibrate again after 2 minutes or so. Eventually you'll break into your Home screen.
Or
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Disconnect you phone from your pc leaving the wire connected to your phone not your pc.
open itunes
hold sleep wake button + home button until your screen goes blank...
let go of sleep wake button and continue to hold home while plugging back into pc... should take about 15-30sec and itunes will see your phone in restore mode
IF THIS NOT WORKING
Try rebooting you phone by plugging it into the charger & turn wall socket on
If that also does not work then you need to take it the apple store.. They will replace it or service it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
5helpful
5answers
My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
I Mate K-Jam
Hi There
it seems your phone is stuck in bootloder mode...try to hard reset your phone...and reinstall OS if required....
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
32helpful
21answers
Cannot get PC Studio 3 to work properly
Ok.... found this on another forum, tried it and it works! Fixed my problem, which was exactly the same as yours. Unplug usb cable from phone Type *#52828378# into phone and this comes up 1 Trace setting 2 OTA type setting 3 Serial test 4 TFS reset select 3 serial test and this comes up 1 PPP UP 2 Serial download 3 Run TCK Select 2 Serial download The phone will reboot and once its rebooted connect usb cable and pc studio will work.
2helpful
4answers
Unsucessful Rom Upgradation Error
OK your phone is most probable stuck in bootloader mode and needs to accept a USB connection with the correct ROM image to be reprogrammed. You will see on the screen that there stands Bootloader/Serial if you look carefully. Check if you can see this text. Try a master reset on the phone as per rom installation instruction. (Top mennu buttons and reset simultaniously). Let me know there are more ways to solve the problem.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
